new to site and need help
Old Sep 7, 2008 | 06:05 PM
blwn82z's Avatar
whats up.i have a 82 Z28 i just put a quick performance ford 9" with drag disc brakes.i need help with the brake lines.is there a brake line kit out there or is it all fab as you go. also do i need to run a proportioning valve.any pics of you rearend swap will be great.thanks.sorry i posted this in wrong forum the first time
Old Sep 16, 2008 | 02:07 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: new to site and need help
What calipers are on the new rear, stockers or Wilwood/Strange? You will likely need an adjustable prop depending on which calipers and rotors you have. Please reply with more info.
Ed
Old Sep 17, 2008 | 05:54 PM
blwn82z's Avatar
its a quick performace crate rearend with there brake set up they said they are 12in.disc with stock single piston calipers off a new passenger car that uses banjo fittings.if that helps. thanks.blwn82z
Old Sep 17, 2008 | 10:29 PM
ebmiller88's Avatar
Got a website link?
Ed
Old Sep 18, 2008 | 05:38 PM
blwn82z's Avatar
http://www.quickperformance.com they have a section for the flexable line i need to know about the hard lines.
blwn82z
Old Sep 19, 2008 | 01:02 AM
ebmiller88's Avatar
If you got Wilwood drag brakes the calipers will have a pipe fitting for a brake line connection. You will likely need these parts to connect to your hard lines:
1) -3AN to pipe fitting for the caliper
2) -3AN brake line
3) -3an to hard line fitting.
Good luck.
Ed
Old Sep 19, 2008 | 10:34 AM
blwn82z's Avatar
thanks for the help Ed
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
FueledSoul
Sep 30, 2015 09:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
