3rd gen line lock with a 4th gen master
Old Sep 8, 2008 | 09:05 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The title says most of the question. I am in the midst of a rebuild/LS1 swap and to clean the engine compartment up a little I would like to use a 4th gen master cylinder. I already have the SLP line lock, I would like to know if I the fittings will thread in correctly.
Old Sep 8, 2008 | 10:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 3rd gen line lock with a 4th gen master
Hooks up just perfect!!!!!!!!!!!!!!
Old Sep 10, 2008 | 04:55 AM
Omega's Avatar
Engine: LS1 / LS3
Thanks!
Old Oct 1, 2008 | 01:24 AM
mean350rs's Avatar
Car: 1989 Camaro RS
Engine: 355 LT1
Axle/Gears: 4th gen 10 bolt
any advantages with useing the ls1 master over the factory third gen?
Old Oct 4, 2008 | 10:42 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Prettier, easier and less of a mess to fill.
They're a LOT more expensive from the parts house though. I mean, the factory one is like $23. The 4th gen one is like $160.
Also, if you convert over to a hydraboost setup, you'd need a 4th gen MC or to machine down the thirdgen one. Looks cleaner with a 4th.
Oh, and it's one of the few master cylinders with the exits on the passenger side of the MC, rather than the driver's side, which would be too close to our shock tower. A while ago someone told me of another one that exited on the side to swap to, but I've forgotten it.
Old Oct 4, 2008 | 10:48 PM
krisb410's Avatar
I bought mine for $20 on ebay
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
