C5 brakes on 16" ?
Car: 1987 Iroc Z
Engine: 350 ci.
C5 brakes on 16" ?
I know I look long enough I could find this but save me some time. Will C5 brakes fit behind stock 16" Iroc. I am just looking to put the biggest brakes possible behind the stock wheels. Give link to blue prints for brakets also.
Corvett brakes look cool
Car: 87 GTA
Re: C5 brakes on 16" ?
Check out
EBMiller <--Site Sponsor
or
BigBrakeUpgrade.com
What you can't figure out by reading there, I'm sure they can answer.
or
BigBrakeUpgrade.com
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
C5s won't fit 16" wheels but the 13" C4 HDs will, as will a 13" a custom Wilwood 4 piston kit. These are about the biggest you can fit in there.
HDs:
Wilwoods:
Ed
HDs:
Wilwoods:
Ed
Car: 1992 Z/28
Axle/Gears: 2.73's I think
I was told by someone on here, forget who (have to check PMs) that they fit a pair of C5's behind the 91/92 5 spoke wheel, by trimming the stiffening ribs on the caliper. I bought the kit, and intend to do that this winter... I would assume you have less clearance in an IROC wheel though...
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I don't like the idea of cutting off the stiffening ribs. Wouldn't that be dangerous in weakening the caliper?
Car: 1992 Z/28
Honestly, I wouldn't think so, but I'm far from an engineer. It was only to make the ribs portion even to the rest of the casting. Since the LS1 doesn't have as much in this area, it might be (as) necessary for them. I guess we'll see.
Socal was the name of the member who also did this. Here is a description and pics from him:
I used a 4.5" grinder started w 36 girt flaper wheel pad then went 80 and finished in 120
http://i146.photobucket.com/albums/r...2/IMG_2037.jpg
http://i146.photobucket.com/albums/r...070707_005.jpg
http://i146.photobucket.com/albums/r...070707_004.jpg
http://i146.photobucket.com/albums/r...070707_003.jpg
http://i146.photobucket.com/albums/r...2/IMG_2036.jpg
http://i146.photobucket.com/albums/r...2/IMG_2035.jpg
http://i146.photobucket.com/albums/r...2/IMG_2034.jpg
Here is his website:
http://joshrmz.com/c5bigbrakeupgrade.aspx
Last edited by Jeffrey Fontaine; Sep 29, 2008 at 09:11 AM. Reason: Added link to website
dbrochard
Sep 19, 2015 08:13 PM
