9 bolt rear brakes
Old Oct 1, 2008 | 01:28 AM
mean350rs's Avatar
Car: 1989 Camaro RS
Engine: 355 LT1
Axle/Gears: 4th gen 10 bolt
9 bolt rear brakes
i recently bought a 9 bolt out of an 88 z. im wanting to put the brakes off an 89 9 bolt ( bigger rotors better caliper). biggest problem i see is the backing plate. i can get the caliper and rotors thats not the problem. My problem is the backing/mounting plate. where can i get my hands on these?
Old Oct 1, 2008 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9 bolt rear brakes
Ed Miller and/or AndyZ28
More info should you need it:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Oct 1, 2008 | 12:17 PM
mean350rs's Avatar
Car: 1989 Camaro RS
Engine: 355 LT1
awesome, thanks.
Old Oct 2, 2008 | 12:44 AM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
im swaping a 9 bolt disc rearend in place of the factory drum brake 10 bolt. how would i go about doing the brake lines? the line is still on the rear. will it attach to the st0ck line on the car?
Old Oct 2, 2008 | 06:54 AM
JamesC's Avatar
If you're talking about attaching at the T-block, yes.
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
kyleb24
Aug 15, 2015 08:24 AM
1nastygta
Aug 8, 2015 07:38 PM
