Is there any way to tell a rear disc vs. a rear drum prop valve?
Old Oct 14, 2008 | 04:06 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
Just like the title, looking to see if there is a way to confirm it is rear disc just by looking at it. Also, does anyone know the pressure difference between the 1LE and non-1LE proportioning valves for rear discs?
Jeff
Old Oct 16, 2008 | 08:01 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Is there any way to tell a rear disc vs. a rear drum prop valve?
You can't tell by just looking at them, the differences are all internal.
Ed
Old Oct 16, 2008 | 08:06 AM
Car: 1992 Z/28
Well crap. OK, has anyone ever done any testing with the 1LE vs. non-1LE to see what the pressure difference was? Also, what visual differences are there internally? I'm just nervous about buying a used one that someone SAYS is from a disc car, installing it, then having a problem.
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
novaderrik
Aug 10, 2015 12:44 PM
