Front brakes blocked in my Firebird V6
Old Oct 18, 2008 | 06:50 AM
SpaniardV6's Avatar
Hello,
On my V6 Firebird from 1991, my front right brake is blocked, its always braking the wheel .
Last night, this was my front right brake:
I dismount the wheel, and take a look to the brake, and I can't move the disk because the caliper with the brake pad its making force to the disk and braking it.
What I can do?.
Thanks and excuse my bad english
Old Oct 18, 2008 | 10:58 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: Front brakes blocked in my Firebird V6
it is possible that the caliper is seized but, I would suggest replacing the rubber brake line as they have a tendency to collapse. You could use a stock type replacement or a stainless steel braided type. I would also replace the rotor and bearings if it got as hot as the pic you showed. hope this helps
Old Oct 18, 2008 | 11:12 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
That picture looks like it was taken while the rotor was turning. How did you take it?
Old Oct 18, 2008 | 11:42 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
thats not really his rotor. Notice the PORSCHE label on the caliper???? but back to topic, sounds like the caliper is seized and needs replacing.
Old Oct 18, 2008 | 02:02 PM
SpaniardV6's Avatar
hello
I was dismount the brake calipers, and the part marked with the 7 in the next picture its broken .
But I will buy the full calipers and change it. Rotor and pads are in very good state.
Thanks very much for your suggestions
PS: The car was movin with the front right brake bloqued, the rotor was moving while it was blocked and was very very heat! The rotor was this ->
Old Oct 23, 2008 | 07:20 PM
Steve86TA's Avatar
Car: To many to list
I would replace the rotors and pads also.They are all shot..If it got that hot than the rotors are warped and the pads are glazed bad.They are not meant to get that hot.
Old Oct 23, 2008 | 08:33 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Definitely should replace the front brake hoses.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
