C5 rotor replacement
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
ok so when i bought my z, it already had the c5 front brake swap done, and my rotors recently warped, so its time to replace. question is, will stock c5 rotors fit, or is there some kind of machining that needs to be done on the hub to make them fit? i have taken the rotors off before, once the caliper is off, you can just pull the rotor off all by itself, so my intuition tells me that the stock c5 replacements will work, but im not 100% sure
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
Re: C5 rotor replacement
Yes you would use stock unaltered rotors. The only thing to be aware of is the fact the turned down hub must fit inside the hat portion of rotor; so that the rotor is flat against it. I have had some that didn't.
