LS1 brakes moser 9 inch
Old Nov 22, 2008 | 11:58 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Thinking about buying a moser 9 inch, but I would like to run a set of LS1 rear brakes that I already have. Has anybody done this?
Old Nov 23, 2008 | 06:02 PM
84ls1_transam's Avatar
Car: 1984 Pontiac Trans Am
Engine: LS1 Zex Direct injected
Axle/Gears: 4.88 Moser 9"
Re: LS1 brakes moser 9 inch
Moser says it's fine. that's what I am going to do.
Old Nov 23, 2008 | 06:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im using them on my moser rear, just make sure you order the rear setup for the ls1 brakes. They work fine
Old Nov 23, 2008 | 07:45 PM
WIll36's Avatar
Engine: 355, 408
Well I'd like to buy a used rear with explorer disc brakes on it now, but would rather use the 12 inch LS1 swap I already have. Don't suppose anybody knows if the flange on the axle is the same? I e-mailed moser but no reply yet.
Old Nov 23, 2008 | 08:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it would be a snowballs chance in hell that they are the same, in fact i know for a fact that they are different.
Old Nov 25, 2008 | 08:34 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Currently have the LS1 rears on the TA. Have the explorer discs on the Cutlass, totally different flanges.
Old Nov 8, 2009 | 03:37 AM
WIll36's Avatar
Engine: 355, 408
So I'm going to bring this thread back from the dead for another question. I bought a project car with a 9" in it. Has all the options and came with 12" PBRs on it. Looks like I'm going to be parting out my 88 that has an LS1 axle in it. I want to take the PBRs off the 9" and install them on another vehicle that has a 10 bolt rear so there would be no fabrication involved I would just have to buy the backing plates. Then swap the LS1 brakes to the 9" so the faster car has the better brakes. For you guys with LS1 rears on the 9" did you just specify that when you ordered from moser and they gave you different axle retaining/backing plates? Also were you guys able to hook up the parking brake?
deracer
Apr 11, 2016 12:04 AM
Irocguy01
Sep 28, 2015 02:03 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
