Need a little brake booster help
Old Nov 25, 2008 | 04:54 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am in the process of revamping the engine bay so I took all the brake components out to refinish them.
I am at the point where I need to put the brake booster back with the master cylinder. It looks like there is a rod from the booster that pushes the master, but I can't find it anywhere. Did I misplace this part, or does the booster have a recessed rod I can't see?
I really need to know ASAP.
Old Nov 25, 2008 | 10:07 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Need a little brake booster help
The booster should have a little tit sticking out of it and a rod that goes from it to the brake pedal under the dash. The longer rods are normally used on non power braked cars. Someone correct me if I'm wrong here.
Ed
Old Nov 26, 2008 | 10:07 AM
Omega's Avatar
Engine: LS1 / LS3
That is what I was afraid of.. I think I have lost the "tit" so to speak. I hope if I push the rod on the pedal side, it will come out.. the car is 40 min away so it's hard to take a quick look at things.
Thanks.
Old Dec 6, 2008 | 09:44 AM
Omega's Avatar
Engine: LS1 / LS3
Just to help others, the answer is yes, I was missing the rod. Here is a pic:
eustodp
Sep 20, 2015 05:09 PM
dbrochard
Sep 19, 2015 08:13 PM
sylentnite
Sep 9, 2015 02:55 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
