85 Ta brake conversion
Old Dec 7, 2008 | 06:02 PM
outlawnova's Avatar
I have an 85 trans am with drum brakes and the local junk yard has a whole rearend in a 85 camaro with disc brakes. there both 10 bolts so i was wondering if i could just take the brake assembly off that rearend and put it on mine or are the housings ends different? i would just buy the whole rearend but mine already has 373 gears moser axles and a fresh auburn posi so i dont really need the parts. I know i will have to change the proportioning valve and master cylinder but other than that should this swap work?
Old Dec 7, 2008 | 06:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 85 Ta brake conversion
Different. You'd have to mod your axle flanges to make it work.
JamesC
Old Dec 8, 2008 | 09:52 AM
outlawnova's Avatar
What exactly is involved? i cant find anything on this but i did see the article where the rear lt1 brakes bolted right on with a special bracket. the other rearend im lookin at should have the right bracket i need for mounting the calipers. Anyone elses input?
Old Dec 8, 2008 | 09:59 AM
JamesC's Avatar
Ed Miller sells a bracket that will convert your drum to a disc:
http://www.flynbye.com/catalog/i30.html
JamesC
LittleFranks
Oct 7, 2015 11:26 PM
dbrochard
Sep 19, 2015 08:13 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
