Drum/Disc Backing Plate Interchange?
Old Dec 9, 2008 | 05:03 PM
MG66Biscayne's Avatar
Car: 1984 Z28
Engine: L69
Will drum brake backing plates on an 84 rear axle interchange with disc brake backing plates on an 87 rear axle? Here's the story...
The rear brakes and aluminum drums on my 84 Z are in great shape but the rear axle needs a rebuild. I have an 87 disc brake rear with a good posi but old cast iron calipers that don't look worth the effort to rebuild or replace. It kind of goes against common logic but I'd like to swap my drums onto the disc rear. This will give me decent brakes at no additional cost without having to concern myself with the proportioning valve, brake lines, e brake etc. (Future plans do include a 4 wheel brake upgrade but right now I have other priorities.)
Thanks for the help.
Mike
Old Dec 9, 2008 | 06:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Drum/Disc Backing Plate Interchange?
No. You can mod the axle flanges to go from drum to disc, but not the other way around. Should you ever wish to go PRB's on the rear of the disc brake rear, check the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Dec 10, 2008 | 06:11 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Mike
In this case, rebuild the iron calipers with the recall kit and you'll be all set.
Ed
Old Dec 10, 2008 | 11:59 AM
Car: 1984 Z28
Engine: L69
Thanks James and Ed, I appreciate the quick expert response. I actually have the caliper rebuild kit and will now go that route since the backing plates don't interchange.
Mike
Fronzizzle
Mar 18, 2019 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
