testing calipers
Old Dec 30, 2008 | 07:56 AM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
testing calipers
Hi all, wondering if there is a way to test calipers while they are off the car?
reason for this is I bought some ls1 rear brakes and the outer seals look suspect and I want to see if they are operating properly before they go on the car.
Can I hook them up to the air compressor(psi? mine goes to 125), place a block of wood in front of the piston to prevent it from shooting out and will that show me if they are working properly?
Any input welcome!
KeithO
Old Dec 30, 2008 | 09:01 AM
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
Re: testing calipers
Yea, that would work. Just be careful that you don't push the piston out too far.
I would put some brake fluid in the caliper first then you would be able to see any small leaks.
Make sure the wood doesn't come out that piston will eject like a bullet.... I've seen one punch a hole in a glass block window.
Old Dec 30, 2008 | 12:42 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
I put them in the bench vise and the clamps prevented the pistons from coming out. It took about 90 psi to get them out and no visable leaks.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
dbrochard
Sep 25, 2015 04:56 PM
Numbah-1
Brakes
Sep 21, 2015 05:18 AM
