Parking Brake Adjuster Assembly
Old Jan 1, 2009 | 04:46 PM
gangsta_money23's Avatar
Car: 1982 Camaro Z-28
Transmission: manual
My e-brake wasnt working at all (bought the car 4ever ago and its been sitting while ive been working on it) so i checked the handle and everything was hooked up just fine and working.
So i got under the car and took a look the the adjuster assembly assuming it was too loose. I found both parking brake cables werent even connected to the adjuster assembly so i found out why the parking brake didnt work. I put the cables in the way they needed to be and went to tighten done the adjuster bolt but its completely rusted and wont move either way.
Is there a way to get the bolt off or what i'd rather do is remove the entire assembly and replace it. Any one know how i could do that? None of my manuals mention anything besides how to adjust not to remove. Thanks a ton guys.
Old Jan 1, 2009 | 04:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Parking Brake Adjuster Assembly
What part are you calling the adjuster?
Old Jan 1, 2009 | 05:08 PM
the plate where the two brake cables go in to. the whole cable runs from the parking brake handle down through a hole in the bottom to a metal plate/piece that the brake cable from each back wheel connects (one on each side)
also the cable from the e brake handles becomes a bolt after that plate
Old Jan 1, 2009 | 05:23 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
The cable is easy to replace. Probably easier just to replace it than try to free it up.
Here is a link to a replacement cable.
http://shop.oreillyauto.com/ProductD...pe=686&PTSet=A
Old Jan 1, 2009 | 05:40 PM
i have to free it up to be able to tighten it down is the problem. that does look like the right cable coming from the e brake handle though. I have the replacement cable the adjuster plate i just have to get the old nut off first so i can remove the plate
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
