Messed up Prop Valve
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Ok, so I was testing the brake pressure coming out of the Prop valve for the left side... Ended up stripping the threads on the outlet for the left front brake.
So do I either go get an OEM replacement...
Or
Go with this?
https://www.thirdgen.org/propvalve
If I do the adjustable prop valve and T the fronts, what do I do with the wires for the pressure sensor in the OEM valve?? I think all it does is sent off the light on the dash when pressure is low?? Does it throw codes in the ECM?
Or
Go with this?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
