Question about 84 posi w/disk
Old Jan 18, 2009 | 08:45 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I've done a search on this but didn't get the answer I was looking for. I'm picking up a (supposedly) rebuilt 84 posi/disk/3/73 for $200. My question is.....did the 84 come with disk?....and if it did and it has the 10.5 rotors, can I upgrade to 12" disk? Is this an aftermarket upgrade or thru GM?
Old Jan 18, 2009 | 09:33 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Question about 84 posi w/disk
Was that the one on Craigslist? You beat me to it ): It's okay though I didnt feel like pulling it haha
Old Jan 19, 2009 | 12:40 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Yes, factory discs were available in '84 (my '83 has them).
Flynbye.com is one good source for brake upgrades. There are others, also.
Old Jan 19, 2009 | 02:31 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
yeah.....it was, sorry Killert. I almost had it for $75!! Hopefully it's in good shape
Old Jan 19, 2009 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by jb3829
Iand if it did and it has the 10.5 rotors, can I upgrade to 12" disk? Is this an aftermarket upgrade or thru GM?
It was 10.5' rotor and single-piston iron calipers. You can upgrade. The front are easiest done through an after market vendor, such as Ed Miller's site (mentioned above), but you can do both fronts and rears yourself. Following is one such upgrade:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Jan 19, 2009 | 04:31 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thanks for the info guys....I'm assuming I'll need the e-brake equalizer off the 84 as well as the PV? Or can I work with what I have already? From what I've searched here, some say yes and no. I checked out the flynbye site....HOLY CRAP! $900 for the rear upgrade???
Old Jan 19, 2009 | 08:13 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I have brand new never used OEM fully loaded calipers and probably every thing else you need to do that swap including new backing plates.
get a hold of me if you are interested.
Old Jan 19, 2009 | 08:30 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thanks jj......I'll keep you in mind when I have the $$$$$$$$
Old Jan 20, 2009 | 10:04 AM
Flip 2's Avatar
Engine: C5 LS1
Upgrade is less when you start with a disc brake rear.
Old Jan 20, 2009 | 10:12 AM
JamesC's Avatar
I bought PBR calipers, backing plates, lines, etc. from an 89 with a bent axle tube. By the time I sold the 9-bolt backing plates, the cost for the basics was around $60--yes, I spent more than that by the time I was done, but my point is that if you keep your eyes and ears open, a deal may come your way.
James
Old Jan 20, 2009 | 06:13 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thanks....the rearend I'm picking up has disks so I guess I'll just see what needs to be replaced when I pull it. Hopefully just new rotors and lines. I've read thru a search that rebuilding the calipers isn't all that hard. Can anyone recommend a rebuild kit?
Old Jan 23, 2009 | 07:35 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Pulled the rearend today.....I got that, plus the master cylinder/proportioning valve......and an entire 3" Borla stainless steel exhaust for $250!!
Old Mar 3, 2009 | 11:12 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
^^^if you ever want to sell that exhaust system let me knnow
Old Mar 4, 2009 | 11:34 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thanks but it's in the shop now getting installed.......I will sell the 80 series Flowmaster catback though. It has less than 500 miles on it
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mcgarnicle
Aug 12, 2015 04:58 PM
