Prop valve necessary?
Old Feb 1, 2009 | 08:17 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Last yearI replaced the stock rear in my 88 IROC with a rear end out of a 98SS. Went from drums to discs. I think the car brakes just fine. What am I missing? Leave well enough alone? thanks
Old Feb 1, 2009 | 10:01 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Prop valve necessary?
Hey there! I see your from MN too. I have heard people say that the brakes work fine with the stock prop valve, but if you want the "right" pressure/volume i would put it in. So in short, no it is not necesary (spelling i know) but it might be beneficial.
Old Feb 4, 2009 | 10:22 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
If you put the right prop valve in, you will see for yourself the difference it makes.
Old Feb 4, 2009 | 10:26 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Recommendation?
Old Feb 4, 2009 | 10:30 AM
krisb410's Avatar
Replace the disc/drum prop valve with a disc/disc prop valve. Drum brakes use the volume of fluid, where as disc brakes use the pressure of the fluid. I may have these reversed. But the point is, Yes the rear discs will work with a disc/drum valve, but they will work better with a disc/disc valve.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
