rear disc conversion
Old Feb 17, 2009 | 09:07 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
I have an 87 GTA with rear drum, I got a rear axle with PBR disc brakes from an 89 GTA.
Can I use the 87's axle and change the mounting bracket, calipers from the disc axle or do I have to change the whole axle?
Old Feb 18, 2009 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear disc conversion
Originally Posted by transamice
I have an 87 GTA with rear drum, I got a rear axle with PBR disc brakes from an 89 GTA. Can I use the 87's axle and change the mounting bracket, calipers from the disc axle or do I have to change the whole axle?
You'll either have to mod the drum's axel flange or purchase a conversion piece from Ed Miller: http://www.flynbye.com/catalog/i30.html
You'll need to proportioning valve whether you do as above or swap years entirely.
JamesC
Old Feb 18, 2009 | 07:59 PM
transamice's Avatar
Car: 87 GTA t-top
I have the brackets from the 89 axle though, 4 bolts and they come off.
Just didnt know if I can use the same brackets on the 87 axle, will save me from switching the whole axle and changing gears again.
Old Feb 18, 2009 | 08:54 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can modify the drum flanges to accept the disc backing plates and you'll be fine, similar to how you would modify the drum flanges for LS1 rear discs. Or just get the conversion plates. Please note you'll have to have the drum axles turned down to fit inside the '89 discs or buy new ones for a '93-97 which will install over your drum axles.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
