83 10 bolt disk rear. Need source for parts
Old Jan 11, 2009 | 02:11 PM
joshl's Avatar
Car: 83 z28,96 e150,00 zx2
Transmission: T5WC
Axle/Gears: 4:56 eaton posi disc rear
First off, these are not PBRs and i AM NOT INTERESTED UPGRADING .What i need is the brass junction block for the left caliper. It is the block that the hard line screws into and it has a banjo bolt through the middle which holds it to the caliper. I also am missing the e-brake cable return springs that go on the back of the caliper for both calipers. These are the springs that push the parking brake lever back (the ones on the calipers) when the handle is released. I am just looking for a possible source to buy these parts as the dealer and the part stores say they are No longer available.
Old Jan 11, 2009 | 08:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 83 10 bolt disk rear. Need source for parts
I have the parts on hand but let me check for you to be sure I have both return springs. If you're interested I also have recall kits for the old calipers as well.
I'll get back to you.
Ed
Old Jan 11, 2009 | 08:20 PM
joshl's Avatar
Transmission: T5WC
new to the camaro scene. what are the recall kits you speak of? These are new calipers from local auto parts store but I never had the springs and the block is stripped. I just bought everything from another user that I have dealt with before but could you shed some light on the recall thing?
Old Jan 11, 2009 | 11:05 PM
ebmiller88's Avatar
Those old iron calipers are known for locking up and not working right, the recall kit (rebuild kit) takes care of the faulty designs and makes them work right. No way to tell if your new ones will have it installed or not but it's likely they won't. Good luck!
Ed
Old Jan 12, 2009 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by ebmiller88
Those old iron calipers are known for locking up and not working right...
Which is one of the reasons that people upgrade.
JamesC
Old Jan 12, 2009 | 02:54 PM
joshl's Avatar
Transmission: T5WC
JamesC: well I can understand the reason that people upgrade but, this is not a high performance car just your average camaro. No trips to the strip and no hot ******* on the streets. I am not afraid to work on the car either so if they need work I fix them. The car is exactly as I received it and the only thing i am changing is the gears and new paint.
How much are the recall kits? May be interested in just having set on hand if the need arises.
Old Jan 12, 2009 | 09:23 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
You dont need a high performance race car to appreciate better brakes. I have the PBR rears and its night and day to the drums i had before. Even in normal driving. Braking is one area i dont like to skimp on. It stops closer to what a new car stops like now. Still not great..but better.
Old Jan 12, 2009 | 09:28 PM
ebmiller88's Avatar
I'll PM you, one kit does both sides. They're discontinued from GM now as are most parts.
Ed
Old Jan 12, 2009 | 09:58 PM
joshl's Avatar
Transmission: T5WC
subroc: This car won't see more than 500 miles a year. 7 miles each way to work on nice days...that's it. I'm not gonna spend the money to upgrade brakes for the little use they will see. I have too many other vehicles that see far more use and the money will go to them for upgrades.
ebmiller88: got your pm. I'll get back to you on that via pm.
Old Feb 18, 2009 | 09:32 PM
85camaronub's Avatar
Hi there, i am also in need of the brass junction block for a 85 camaro. the disk brake rear i swapped in is standard and i need a metric brass union for my new SS lines. If anyone knows were i can get 1, it would be greatly appreciated.
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
