LT1 Brakes
Car: 86 Z28
Axle/Gears: 3.42 posi
LT1 Brakes
I picked up a fourth gen differential today, it has pbr aluminum calipers on it, just wondering what brakes were available on the 4th gens, and what proportioning valve I should use with them?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LT1 Brakes
you could get drums, lt1 discs, 11.25"? and ls1 discs 12". A disc/disc prop valve will do fine. A 1le prop valve would be ideal
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: LT1 Brakes
https://www.thirdgen.org/forums/engi...rake-prop.html
JamesC
Car: 86 Z28
Re: LT1 Brakes
i actually did get a prop. valve with it, the guy said it was from a buick with either full disc brakes or very big drums. there is a number stamped on it, would that have any relevence? I can get the number tomorrow if that would help.
Re: LT1 Brakes
JamesC
Car: 86 Trans Am
Re: LT1 Brakes
i wouldnt bother with the prop vavle you got with it, its not from a 3rd gen, so we dont even know if the thread sizes/flare type, port orientation, are the same, and we dont even know if its a disc/disc prop. Not sure where you could cross reference that number
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: LT1 Brakes
Ed
Car: 86 Z28
Re: LT1 Brakes
how much would you want for one? I will have to wait awhile I spent all my money buying the differential. would it work okay if i left the disc/drum prop. valve in there or would the rear brakes lock up right away?
Re: LT1 Brakes
Sent you a PM. The drum one will work OK, I know some guys on here still run theirs but to be "correct" you need a disc one. They won't lock up right away, the drum valve just doesn't give the right pressure.
Ed
Ed
Re: LT1 Brakes
Ok so will I need to get the 89 and up prop valve since I have an 86 with the crappy iron calipers on the rear? I have 95 camaro rear calipers I'm just trying to acquire all the parts I need before I do the swap.
Thanks cameron
Thanks cameron
Car: 86 Z28
Re: LT1 Brakes
either would work, but the 89+ would be better, and an adjustable would be best, but I don't know for sure as I have yet to get the differential in(too cold to paint)
dbrochard
Oct 3, 2015 12:43 PM
New2Chevy
Sep 28, 2015 12:35 AM
