*Custom* high-temp paint?
Old Mar 18, 2009 | 11:33 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Hi all,
I'm going to be swapping over to a set of 13" Baer brakes (that I bought used) within the next few weeks, & I'd kind of like to paint the calipers while I still have them off. The problem that I have is that I want the calipers to match the color of the car (Flame Red Metallic) or to at least be fairly close anyway.
The high-temp red paints that I've bought so far are all more or less the same thing - a really bright red that I think would look entirely inappropriate with the rest of the car. (Think "Ferrari red" or similar.) Is it possible to get 1200* paint in more than the "standard" 5 or 6 colors?
IDEALLY, I could get something that would be subtly different than stock, something that would show up behind/through the gold GTA wheels, but wouldn't scream "look at me!!". (I've considered black, but I can't seem to get enthused about that...) I suspect that I'm wanting something that's going to be either impractical, or really $pendy - but I figure "what the hell", it can't hurt to ask, right?
Thanks guys.
Old Mar 19, 2009 | 01:24 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: *Custom* high-temp paint?
I found that the Metal Cast paints actually hold up to high brake temps and maintain there shine for a really long time.
I used a VHT caliper paint and I got one that was blue and used it as my base, then I put a little metal flake (base coat metalcast) for a little sparkle and then a couple light coats of top color. It turned out really nice but I was skeptical if it would hold out and it has lasted a couple years and still looks nice. The paint when dry looked wet and deep and held up to red hot rotor temps.
Old Mar 24, 2009 | 11:28 AM
V8Rumble's Avatar
Thanks crytical, it looks like that's what I'll try then. I found the following when doing a bit of follow-up on your post:
"Metalcast is heat resistant and can be used in high heat applications such as engines and brake calipers."Link
And since it appears to be somewhat transparent, it looks like it's possible to vary the color to some extent (depending on thickness & color of basecoat), so I should be able to get fairly close to what I want. Thanks for the pointer.
Old Mar 29, 2009 | 07:51 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are you rebuilding them before install? Have the caliper bodies powdercoated.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
Billy Decker
Sep 4, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
