Rear Caliper Mounting Brackets
Old Mar 28, 2009 | 11:12 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Noticed a major problem with my right rear Caliper Mounting Bracket for my 87 IROC the other night. I have a standard 10 bolt and am unable to mount the right rear caliper as it appears that the diff was dropped. You can't order these from GM anymore as they stopped making these about 12 years ago and they aren't listed on Hawks or Classic Industries. I have pretty much exhausted all resources that I have looking for these. Does anyone know where I might be able to buy them at?
Old Mar 28, 2009 | 11:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Caliper Mounting Brackets
Since many members have upgraded to bigger brakes and consequently different backing plates, I'd think the site's classifieds might be a good source. The bone yards, of course, would be another avenue.
JamesC
Old Mar 29, 2009 | 08:44 PM
1985hotrod's Avatar
If the bracket bolts to the rear end housing and is separate you should be able to buy what is called a loaded caliper that will come with the bracket. I was in the Brake bus. for many years and ran into this alot.
Old Mar 30, 2009 | 09:08 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Nope, I work at Autozone part time and 99% of the time the brake caliper brackets will not come with loaded camaro calipers.. The reason for this is you have to remove the rear axle's to get the caliper mounting brackets off the differential.
Old Mar 30, 2009 | 09:12 AM
JamesC's Avatar
However, the 'carriers' often come with PBR's, 89-92.
JamesC
Old Mar 30, 2009 | 03:21 PM
ibmtech's Avatar
Car: 1987 IROC-Z
That would work also if I was looking for PBR caliper & brackets. But, I am looking for the stock 87 caliper brackets which came with the Delco Iron calipers.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
