front brake upgrade to match lt1 rear
Old Mar 31, 2009 | 05:27 PM
3vi1p3nguin's Avatar
Car: 85 Iroc-Z
Engine: 350 4bbl
ok. i know this question has been asked before, but the more i read i think the more I get the brakes confused. I've got a 4th gen rear that im going to be stripping to install into my 83 rear that I just got (4th is in the car and I dont like the looks) but it brakes weird with the bigger brakes in the back. If i remember right the later RSs had bigger front brakes than my iroc, but they get different spindles? The reason I ask is theres one at a bone yard near me and I could get the spindles and brakes cheap, as I dont have the cash for the c4 upgrade yet.
Old Mar 31, 2009 | 05:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: front brake upgrade to match lt1 rear
There are two fourthgen rears, the LT1 (93-97)and LS1 (98+).
All thirdgen front brakes are the same, to include spindles: Delco-Moraine iron calipers with 10.5" rotors. The exception is the 1LE, which had dual piston alum calipers and 11.7" rotors.
JamesC
Old Mar 31, 2009 | 05:38 PM
Car: 85 Iroc-Z
Engine: 350 4bbl
i have the lt1 rear, its out of a 94. sorry guess I'll just have to wait for the c4s i guess
Old Mar 31, 2009 | 05:41 PM
JamesC's Avatar
BTW, the 1LE set-up and its alum calipers will match the LT1 rear and its PBR's.
JamesC
Old Mar 31, 2009 | 05:48 PM
Car: 85 Iroc-Z
Engine: 350 4bbl
i also have the lt1 master that I could install. does that make any difference?
Old Mar 31, 2009 | 05:53 PM
JamesC's Avatar
No. If you're going from drum to disc, swap the proportioning valve for best brake performance. You'll need to consider e-brake and the drive and/or driven gears as well. Check the following FAQ (toward the bottom) for more info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 31, 2009 | 06:00 PM
Car: 85 Iroc-Z
Engine: 350 4bbl
yeah, the gears and everything will work when i switch over. everything is staying 3.42 brakes were the only debate. i think that Eds going to be getting lots of my money this summer
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
