Two fast brake question
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
OK, right now I'm looking at getting a new set of rims, so I want some nice brakes to be behind them mainly getting those ugly drums out from behind them. So got some questions.
1. Where should the stronger brakes go? Front or back.
2. A set of brakes I want to get say "front" in the description. Can I use them as rear?
Thanx
Thanx
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Two fast brake question
Car: 84 frankenstein Z28
Car: 90 Camaro RS
Engine: V6 3.1 MFI
OK Thanx, the brake I'm looking for the back are these 2 Piston Aluminum Caliper w/38mm Stainless Pistons. but I guess I won't be pulling those on the back because they would be better then the stock front.
http://www.flynbye.com/catalog/i10.html
JamesC
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Odd enough, from 89-92 all four-wheel disc brake cars (J65) were equipped with 10.5" front rotors and 11.7" rear rotors (with alum PBR calipers). Crazy. Anyway, should you wish to do what was stock from 89-92, note that Ed Miller sells a bolt-on drum to disc conversion kit:
JamesC
JamesC
