prop. valve question....
Old Mar 30, 2009 | 05:31 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
ive got 1le fronts on my 1983 ta. stock drums in the rear. my 1le's came with a prop. valve but do i need to swap it or is it ok??
Old Apr 1, 2009 | 10:21 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: prop. valve question....
Not really, as the prop valve alters pressure to the rear, the front almost always gets full pressure from the master cylinder.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
