Difference Between Performance And Standard Rotors?
Old Mar 30, 2009 | 09:54 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
How do you tell if you have standard or performance factory rotors? My rotors are so warped you can just look at them and tell.
Alex
Old Mar 30, 2009 | 10:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Difference Between Performance And Standard Rotors?
The only "Performance" brake package is the 1LE, which is pretty distinctive with its 2 piston aluminum front calipers. Everything else uses the same rotors.
Old Mar 31, 2009 | 03:54 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Standard front rotors are 10.5 " in dia except the larger ILE performance rotors. Most parts stores ask this question and I don't know why?? When 98% plus 3rd gen cars have the standard front 10.5 rotors.
Old Mar 31, 2009 | 05:42 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
When i went into get a bleeder screw for my front brakes(non-1LE) they had them for both the HD brakes, the regular ones, and the 1LE brakes. I thought it was odd since you could only get the crappy iron ones up front or 1LE's. Anyways turns out that the parts for the HD and the regular ones are the same. I had him run various part numbers and compared them. IDK why they think we have any sort of HD brakes or anything. Quite odd. As for why they might offer like performance rotors, those could be slotted/drilled ones also.
Old Mar 31, 2009 | 06:00 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Yes, but I've been asked if the car had a performance package. I've never gone through and compared the two.
Old Apr 1, 2009 | 10:10 AM
Thanks for the info guys. For some reason the place I buy parts from (rockauto.com) sells the ILE rotors for less than the standard ones.
Thanks again
Alex
Old Apr 1, 2009 | 10:42 AM
84redta's Avatar
I don't mean to hyjack this thread, but here is supporting details which i would like to know before i think about going ahead with this. They have standard rotors available, and napa has performance being slotted and drilled. But as far as pads and calipers, here are two options:
one piston for the front:
http://shop.advanceautoparts.com/web...S_676893314___
two piston for the front:
http://shop.advanceautoparts.com/web...S_676887628___
and as far as brake pads, i've found this which look like the dimensions of the two piston calipers:
http://shop.advanceautoparts.com/web...OAMS__Brake___
is there a one piston and two piston assembly that is interchangable? or is this the 1le stuff?
Old Apr 1, 2009 | 10:56 AM
DJP87Z28's Avatar
They don't interchange. They will not work end of story. Do a search if you want more info....
Old Apr 1, 2009 | 11:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The two-piston is the 1LE. DJP's correct: no interchange (without modification). For that check the following link:
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
Old Apr 1, 2009 | 11:39 AM
84redta's Avatar
I understood the 1LE modifications, i just wanted to make sure that they were 1LE parts before considering them or LS1's up front. Where would one get 1LE rotors even?
Old Apr 1, 2009 | 11:46 AM
JamesC's Avatar
I purchased some from Advance Auto last summer.
JamesC
Old Apr 1, 2009 | 11:52 AM
84redta's Avatar
Thank you James. I checked their website and they had it grayed out.
Jon
Old Apr 1, 2009 | 01:01 PM
rockauto.com has them for $24. I think they have slotted and drilled stuff too.
Alex
Old Apr 1, 2009 | 02:56 PM
Saber's Avatar
I have seen listings for 1LE rotors at napa, advance and autozone. Most of the time they come from a factory or warehouse on special order.
Its cheaper to get LS1 brakes up front. Finding 1LE stuff is usually expensive because its some pretty rare equipment when compared to the LS1 setup.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
