rear caliper compatibility
Old Apr 22, 2009 | 09:18 PM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
Transmission: TH700R4
Are the rear disck brake calipers from 93 - 95 compatible with the ones from 91? Specificaly the emergency brake cable bracket and spring.
I am having trouble locating the emergency brake cable brackets and springs that go on the calipers for my 91 and I am looking for alternatives. Thanks
Old Apr 23, 2009 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear caliper compatibility
93-97 LT1 calipers are nearly identical to the 89-92 version.
billybob may want to dump the very things you need. Check post 28 of the following link:
https://www.thirdgen.org/forums/tech...nd-swap-2.html
JamesC
Old Apr 23, 2009 | 07:45 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
That is awesome, thanks! I'll chase that down, failing that I have a line on some 94 calipers, and it sounds like I should be able to swap those in, or borrow the bracket / spring off them.
Old Apr 25, 2009 | 10:36 PM
bigals87z28's Avatar
Car: Check The Sig
So you can or cant use LT1 rear calipers?
Old Apr 26, 2009 | 06:58 AM
JamesC's Avatar
Can.
JamesC
Old Apr 29, 2009 | 08:57 AM
Car: Check The Sig
Awesome. It looks like I wont need it now, but a good idea in the future. Is there any advantage going to the LT1 style?
Old Apr 29, 2009 | 09:18 AM
JamesC's Avatar
Not over the 89-92 version.
JamesC
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
