How much rear brake pressure do you run...
Old Apr 27, 2009 | 01:02 AM
JERRYWHO's Avatar
I have LS1 brakes on the front and rear with Hawks HPS pads and a LS1 master cylinder. What rear pressure and brakes are people running here.
Jerry
Old Apr 28, 2009 | 08:33 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: How much rear brake pressure do you run...
Im not sure what pressure im running but what i ended up doing was putting the rear of the car up on jackstands, putting it in gear and just adjusting the prop valve until the rear brakes grabbed the rotors and held them. Its not an exact science but it seemed to do the job for me
Front brakes are stock disks, rear are stock PBR with 11.5 inch rotors.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
