Spindle hub play?
Old May 9, 2009 | 09:37 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Spindle hub play?
About a year ago I decieded to the front C4 do it yourself upgrade. But last summer came in to play so I put it off til this past winter. Anyway after doing the 1Le rotor to hub modification and then mocking it up to the spindle I found that when I put the inner and outer bearings in with the washer and castle nut and just snug it tight. I'm getting about a 1/2" of play by sliding the modified 1Le hub back and forth on the stock spindle. Is this normal or what?
Old May 11, 2009 | 12:18 PM
Car: 1988 IROC-Z28
Re: Spindle hub play?
just an update, I was using the wrong outer bearings which were my old stock bearings. I picked up the 1Le bearings and everthing fits like a glove.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
rusty vango
Sep 29, 2015 02:44 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
