89 4 wheel disk. LS1 fronts upgrade. Which Prop valve?
Yes I searched SO MANY THREADS. So little hard info.
I've got the standard sucky fronts, with the PBR aluminum rears. Getting ready to upgrade to LS1 fronts.
What prop valve is best?
I've seen a few people use the 1LE. Is that best, I don't know?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: 89 4 wheel disk. LS1 fronts upgrade. Which Prop valve?
I think it would be the right one since thats what Ed sells in his LS1 kit IIRC.
EDIT: In Eds LS1 rear setup he includes a 1le prop, not sure on the fronts though.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the 1le is the best
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
1992rs/ss
16
Jan 28, 2016 09:58 PM
