What size fitting front brake line.
Old May 18, 2009 | 11:35 AM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Changing front brakes to strange units. What size is the caliper end of the front factory flex lines? I know they say that they wont work so Im going to try and find a fitting that will.
Thanks,
Aaron
Old May 18, 2009 | 12:17 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: What size fitting front brake line.
if you still have the brakes off the car just take them into a auto parts store and try it out. you can never depend on what they should be. you dont want to get a number - buy the fittings, take the old ones off, put the new ones on, put the brakes on and then find out it does not fit. there are times when mfg's run out of something and grab a part similar in size. it will not hurt the brakes but it will give you a headache.
or call strange for the size and buy one fitting that size and try it out.
or go to an auto parts store and buy a few fittings in each close size and take the ones that dont fit back.
Old May 22, 2009 | 10:50 PM
Car: 91 firebird
Axle/Gears: 4.30
ok brakes installed cleanly and easy! looks great but no lines lol! the calipers use a -3an so is there any fitting to convert the front hard line to a 3an? what size fitting is on the end of the front hard line?
Old May 23, 2009 | 11:44 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
http://store.summitracing.com/partde...5&autoview=sku
this one i believe
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
knight72
Aug 10, 2015 09:32 PM
