brake lights broke
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
brake lights broke
I have an 89 Trans Am 5.0 with no brake lights now. I have checked my brake switch at the brake pedal and found it to be functional. I dont have the wiring diagram to trace further the wiring to the next place to check. Can anyone help?
Robert
Robert
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: brake lights broke
Most of the time it's not the 10' long straight wire that goes bad, its something at either end, so pull the rear lighting assembly and pull the bulbs out of their socket in the box. Check to make sure all wires are firmly in their connectors, and then check to make sure you didn't blow any bulbs themselves.
Check fuses also, and as for wiring diagrams I only have them for camaros sorry :/
