86 camaro rear calipers
Old Jun 12, 2009 | 12:41 PM
dusterbd's Avatar
im gonna rebuild these things before i do the conversion on my project. ive been searching, and cannot seem to find the rebuild and adjustment procedures. they seem very similar to the eldorado calipers i did once, and thise were never right again, so id like to do this properly the first time. i already have the rebuild kits, i just now need the procedures.
thanks for any help you guys can throw my way.
Michael
Old Jun 12, 2009 | 12:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 86 camaro rear calipers
Check the following:
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Old Jun 13, 2009 | 12:20 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i pick ed up GM # 18019028 you can see it here http://www.gmpartsdirect.com/ ...my two reasons for rebuilding the calipers was the DASH Brake warning lit, and i had missing anti-rattling clips. you need the cube tool to turn the pistons out and turn them in. im rebuilding my system Tuesday because of a on-order brake hose. In the new rebuild kit for the back, it comes with pistons, seals, spring, and anti rattling clips. im doing the whole system because im pissed at the brakes. i didnt skimp either, i got rotors, hoses all around, pads, rear and front caliper rebuild kits, master cylinder rebuild kit, bearings for the front. i just want it done and out of the way...-mikey ill post pics on tuesday night
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
