LS1 calipers with 1LE rotors?? Will it work?
Old Aug 21, 2009 | 05:46 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I PMed this to ebmiller88 but maybe someone on here can help also.
My original plans were to upgrade to "LS1" brakes with 12" rotors. My stepfather machined the conversion caliper brackets from CAD files found on TGO and I was going to buy the other parts.
Here is the LS1 bracket I had made for me out of 3/8" steel.
Example:
Recently I came across a friend of mine with either 11 3/4" or 12" 1LE slotted rotors that he would sell to me as a pair for a good price.
Here is the question that maybe you guys could help me with.
According to https://www.thirdgen.org/forums/faq-...s1-brakes.html thread, the "LS1" brake rotors are 1.25" thick, which is thicker than the stock 1.05" 1LE rotors.
So, Would I be able to use the brackets that were made for the LS1 calipers with the 1LE slotted rotors?
I understand that either route I go I am going to have to modify a set of spindles.
Has anyone ever done a setup like this before? How did it work out?
I appriciate the help very much.
Thanks,
Dennis
Old Aug 21, 2009 | 09:46 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Re: LS1 calipers with 1LE rotors?? Will it work?
You will not be able to use the 1LE rotors due to the offset, you will not be able to fit the caliper bracket & caliper carrier in-between the rotor and the spindle
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
