4thgen swap pic/info needed
Old Sep 3, 2009 | 03:07 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Anybody have a pic of the routing of 4thgen ebrake cables and this "bracket" that holds it on the LCA? I'm getting a 3.42 out of an '02 Z28 but it's out of the car already and missing some peripheral parts so I want to see if I need to haggle with the boneyard to get them or if I can shoemaker the bracket. Also, this has Trac control and has the 2 brake line inlet "tee" on it. Will the old 1 inlet off my present drum work or will a single inlet off an LS1 axle w/3 channel ABS be required? Thanks.
Old Sep 6, 2009 | 01:18 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: 4thgen swap pic/info needed
Anybody?
IROCZ1989
Jan 24, 2016 03:55 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
