bad master cylinder symptoms
Old Sep 6, 2009 | 08:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so, ive been trying to figure out my pathetic brakes, i have about 1-1.5" of travel in the pedal, then the pedal stops dead, the harder you push, the more the firewall bends. The brakes suck, cant even lock a wheel in gravel, and this is with c5 vette brakes.
I took the master, and prop off, gutted the prop, plumbed in an adjustable rear prop valve, blead everything and i still have the same issue.
If i disconnect the master from the booster, i can push the pedal to the floor. If i bolt the master to the booster, even without the brake lines attached to anything, the pedals only goes an inch or so and gets hard. Im thinking the master is shot?
agreements?
thanks
-Phil
Old Sep 10, 2009 | 05:37 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: bad master cylinder symptoms
When my master went bad, the pedal still felt fine it just wouldnt put any pressure on the front calipers. I found out when doing a brake job and trying to bleed the front brakes there was very little fluid coming from the bleeder screw. Usually the seals inside the master cylinder go bad and you therefore lose pressure. When installing a new master cylinder you push the piston into the master cylinder while bench bleeding the cylinder. You could try taking the master cylinder off the car and pushing the piston in to see if there is an obstruction in the cylinder. Just be careful not to go to far or too fast or you may damage the internal seals.
Old Sep 11, 2009 | 02:49 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
So you got the prop valve plumbed in. Pic's?
I would bet the m-cyl is probably the culprit.
RazorN8's bench test does sound like a good idea.
At the risk of seeming really pi..y, did you possibly
try servicing it, & re-assemble the plungers wrong?
At any rate, I think rebuilt ones are relatively inexpensive --
at least compared to the corvette upgrades in place.
Good luck, & keep us posted.
(I still want to know where you got the bubble flare T.)
Old Sep 11, 2009 | 04:07 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
sounds like the master cylinder doesn't have enough volume. what all do you have on the car (for brakes)?
Old Sep 11, 2009 | 04:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no issue with volume.
c5 vette fronts, 4th gen pbr's for the rear, LS1 4th gen master cylinder, and something was wrong with it, it had a weird leak. I put a new one on and things are better, but still have some air in the system. I should have the adjustable prop re-plumbed this coming weekend and have the factory prop completely removed. then i will have some pics.
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Accerrito22
Sep 5, 2015 09:34 PM
