9 inch with 1LE brakes
Old Sep 6, 2009 | 10:19 PM
1LEZ's Avatar
I am buying a 9 inch from Quick Performance and I was wondering what kind of axels and housing ends I will need to keep my factory 1LE brakes. Also I have ZR1 wheels with 1.5" spacers. Am I correct in assuming that I should have them make the new rear 1.5 wider on each side to eliminate the spacers? Thanks for any help.
Old Sep 7, 2009 | 01:35 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 9 inch with 1LE brakes
Get the rear for LS1 brakes, if you don't spec that you'll get big Ford housings which will not accept the stock plates, I did make some backing plates just for that issue though. And yes, get it in stock 4th gen width and your spacers will go away.
Ed
Old Sep 7, 2009 | 08:57 AM
1LEZ's Avatar
OK, so LS1 is the same as LT1 is the same as third gen 1LE? I mean as far as axle tube ends are concerned? Just don't want to make any assumptions. Thanks for your input.
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
