LS1 front upgrade: Need PN#s for longer metric studs and front lines
Old Oct 5, 2009 | 04:09 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I had these set aside before but can anyone help me with the correct numbers for my LS1 front brake swap:
Firstoff, I need the part number for the longer metric 12mm x 1.25 wheel studs to use in the hubs, I believe they were ARPs even...
Secondly, I read that the 1LE line kit (Earl's #28A190) was discontinued and I cannot find it on Summit / Jeg's etc.
However that line kit was listed as a 4 line kit anyways and dont I want a 5 line kit? (LS1 fronts / factory 89+ PBR rears)
When I look up on the Holley site it gives a 5 line kit as Earl's #692370 with a 3 week backorder. Not sure if this is the one I should order or not...
Please help,
Old Oct 5, 2009 | 07:16 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: LS1 front upgrade: Need PN#s for longer metric studs and front lines
I'm using my stock front hoses (non-1LE) with the LS1 stuff. And the rear has stock hose/splitter in the center and the LS1 hoses on the LS1calipes.
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
