rear brakes stick need help?
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Okay so I did my rear shoes , new return springs ,turned drums , replaced rear hose , and both wheel cylinders and I'm still having a problem with the brakes sticking and getting very hot both sides we don't think it's the master cylinder or the valve , because from what I've read when the valve goes bad you lose brakes same with the master cylinder. I have read about the rod that works the master cylinder could need adjusting but from my understanding if the rod would wear that would also cause lose of brakes so I'm kinda stuck on what to do next i don't wanna just keep throwing parts at it the pedal feel is great they have been bled out with new fluid . I also backed the adjuster way off and they still got really hot. I also removed the e-brake to rule that out still the same problem any info would be great I'm stuck at this point.
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: rear brakes stick need help?
Did you assemble everything correctly, did you clean the shoes with brake clean, and did you lube the adjuster and backing plate contact points?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you install the adjuster for the shoes backwards, it will tighten everytime you drive and heatup the drums, eventually lock up the rear. Not sure if your issue is that bad, but its an idea.
The operation of the drums is pretty simple, so if you leave the drum off and have somebody press the brake pedal, you can watch things work. Maybe you will find something binding, like a spring installed wrong or something like that.
Engine: 355 SBC
that"s the problem everything is correct I have checked it and my father ( who has been a ase certified mechanic for 40 years ) checked it and we are positive everything is right.That is why I'm asking you guys for some help we have checked and double checked everything and while my father is a trained mechanic there may be something that is specific to our kinda cars that we may not be sure of .If anyone has had this problem or has a idea let me know thankyou for helping in advance .
Eric-86sc
Apr 3, 2016 03:52 PM
