brake pad question
Old Oct 17, 2009 | 11:39 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
brake pad question
I have a 92 z28 with 4 wheel disc. The rear disc are the older gm iron calipers with the repair kit from gm. Also there is a line lock on the front between the master and the combo valve . I’m running a set of performance fiction brake pads on front and rear. Most of the time it feels like it has a very hard pedal and won’t even lock up the front wheels. Well recently I was playing with the car and did several hard stops with the car and after the brakes started getting warm it started stopping better. And locking up the front tires. Are these pads less effective when they are cold and not warmed up by repeated hard stops
Old Oct 18, 2009 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake pad question
Yes.
JamesC
Old Oct 24, 2009 | 09:42 PM
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Thank You
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
