need brake upgrade
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
need brake upgrade
got factory brakes on all four corners disk/drum looking to replace the front rotors and pads and converting to disk in the rear. any recommendations would be great. this a street/strip car runs right at 130 for now. and has a 12bolt rear with the 9"ends (4 bolt flange) need some suggestions that wont break the bank. any advantage to doing drilled and slotted in the front? also do i go with semi metalic or ceramic pads. i hear ceramic is very hard on rotors. need help
Billy Decker
Sep 4, 2015 03:46 PM
rudolphschenker
Sep 4, 2015 02:41 AM
