Caliper Adj. stuck
Old Oct 19, 2009 | 11:58 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Caliper Adj. stuck
The e brake adj on my calipers are stuck, this is on a differential from a 95 so it has the PBR calipers. I tried getting it with a metric allen wrench and it just twisted the wrench
Old Oct 21, 2009 | 12:41 PM
Car: 86 Z28
Re: Caliper Adj. stuck
Old Oct 21, 2009 | 12:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Butane bottle and some heat?
JamesC
Old Oct 21, 2009 | 12:51 PM
Car: 86 Z28
i just wasn't sure if i should heat them or not, didn't want to melt something, but if you suggest that then i know i should be good.
Old Oct 21, 2009 | 01:16 PM
JamesC's Avatar
The threads are coated with adhesive, so a bit of heat will probably do the trick.
JamesC
Old Oct 21, 2009 | 09:39 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Get a better wrench (one that won't twist) or actually use a rachet and socket. The map gas torch does wonders too
Old Oct 21, 2009 | 10:57 PM
Car: 86 Z28
ok i will try the torch when i get some time and get a better wrench.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
tmellott89
Oct 14, 2015 02:06 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
