Affordable Rotors
Old Nov 7, 2009 | 08:30 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
Affordable Rotors
Time for the old brake job. However, I am interested in upgrading to drilled and slotted rotors. I don't really care about brands, after searching around it seems that the Summit brand is the cheapest I could find.
http://www.summitracing.com/parts/SUM-DSEP-5547L/
And Jegs has a good deal but I couldnt find any for the front.
http://www.jegs.com/p/Powerstop/Powe...57272/10002/-1
I dont know much about the brake market so any help is greatly appreciated.
Old Nov 7, 2009 | 09:11 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
Re: Affordable Rotors
I just replaced my rear rotors. If you do some searches in this section you will find out for stock applications most of the guys in here with lots of experience will steer you away from drilled and slotted rotors. The posts I read changed my mind anyway. They state that the holes and slots actually create less friction area,therefore worse braking conditions. I had my mind set on the same choices as you,mainly because they just look cool! So I just went to Napa and bought mine. They are 11.6 rotors for the 9-bolt with PBR calipers. I only paid about $65 each and thats because I upgraded to the ones that have the hats and veins coated to prevent rust. Regulars ones are even cheaper. Napa also has the drilled and slotted ones on their website but I don't remember the price of them.
Old Nov 8, 2009 | 01:11 PM
Car: 1992 Z03 RS
The theory of less friction area crossed my mind, but then I am reminded that Vettes and Vipers and Ferraris have drilled and slotted rotors and the pros must out weigh the cons. However, I will research this more.
Old Nov 9, 2009 | 12:07 AM
wvabreeze's Avatar
Those cars have a lot larger disc than a stock maro. Plus those car use multi piston calipers.
Old Nov 9, 2009 | 03:16 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
get the ones you want..just look into the diff brands..
some are better then others.. check out ebay..
your not driving a 8 sec drag car.. or 200mph left turn car..
60 holes in them ..will not make a diff on the street and they will run cooler..
but Buy what you would like to Buy.
Old Nov 15, 2009 | 09:13 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
25 dollar rotors at kragen o'reilys.
Old Nov 16, 2009 | 12:12 AM
thegooseman's Avatar
Car: 1992 RS
http://www.rotorsonline.com/default.aspx
This is the place to go.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
tmork454
Sep 29, 2015 06:33 PM
