c5 breakes soon, why machined hub?
Old Nov 16, 2009 | 01:11 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I havn't been able to find out the reason as to why I need to machine my hubs for c5 rotors. Can someone go into detail as to why I need this done? Thanks.
Old Nov 16, 2009 | 01:57 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: c5 breakes soon, why machined hub?
Your stock rotors have an integral hub installed so that they are a rotor/hub assembly. C5 rotors are just that, rotors that fit onto a hub. Best way to make hubs for your F-body is to turn the friction surface off from a rotor so you can use the stock wheel bearings. I used a set of junkyard rotors to make my hubs, then installed new wheel bearings.
apie2546
Oct 16, 2016 02:24 PM
bigjay89gta
Oct 15, 2015 08:04 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
