manual brakes with a vega master cylinder
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Hey I have someone that has a master cylinder from a vega that was originally manually brakes. Does anyone know if this will work?? I figure its all the same crap I mean this is a O E manual brake so the piston on it must be the right size. All id have to worry about is the fittings fitting but worst case i know how to flare pipe
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: manual brakes with a vega master cylinder
so are you converting your car to manual brakes? if so i have the info you need
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
I used a M/C from a 70 Corvette. I just drilled holes in my original pedal bracket and firewall and had to move the pushrod up on the pedal about 1 inch. You'll have to use the appropriate proportioning valve whether it be disc/drum or four wheel disc. There are kits available for this swap as well. Do a search in the brake board. All the info is here. Good luck.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya thats what im doing but my friend will give me the master cylinder which is brand new for 15 bucks. I know that i need to do all the pushrod stuff and all i was just curious as to how they fit up via fittings and power. I know vegas are smaller so i didnt know.
well okay that makes me feel better that u used a older MC. I already have researched all about it but havent seen anyone do a vega MC
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
