80ish 2nd gen rear with 1le rears?
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Hey guys Im working on a problem for my father and his 1941 sedan delivery. The rear is out a 1980 camaro, I believe it was a drum brake but im not positive. Its got a 4 bolt pattern on the axle tubes. He picked up a set of 1LE calipers and rotor and now I need to know what backing plates will work. Any help would be great!
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 80ish 2nd gen rear with 1le rears?
You should be able to use the stock plates and rotors but you may need to have the axle flanges turned down a bit to fit inside the rotors. Also, due to the staggered shock issue you'll likely need two right side calipers in order to make it work. It's a standard GM 10/12 bolt axle tube pattern.
HTH..
Ed
HTH..
Ed
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
