Help! want to swap out drums for disks in the rear!
Subscribe
Jan 4, 2010 | 06:07 PM
Hello i got an 84 camaro with drums in the rear and i want to upgrade the brake system on the car, so using drums just doesnt seem the correct path to follow. i have read up a little bit on conversions but am not sure which way to do it is the best way to complete this conversion
obviously people have done this in the past and i was wondering if there is a kit online that i can purchase or do i need to find like a 4th gen donor rear to complete this conversion
please can someone explain which way is the best. this is one of the last things that needs to be done to my car before i can put it back on the road
thanks alot
Reply 0
Jan 4, 2010 | 08:31 PM
Re: Help! want to swap out drums for disks in the rear!
http://flynbye.com/catalog/i30.html
Reply 0
Jan 4, 2010 | 08:34 PM
ok so basically i have to remove the old hubs and bolt that directly to the rear end and then i can add whatever calipers and rotors i want
Reply 0
Jan 4, 2010 | 08:37 PM
Check the following FAQ for brake info (parking brake, master, and combination valve, which in your car may have SAE threads):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Reply 0
Jan 4, 2010 | 08:46 PM
Quote: ...then i can add whatever calipers and rotors i want
hmmm not really the above was just for LT1
c5 vette brakes you'll need http://flynbye.com/catalog/i57.html (Just part)
ls1 go for this http://flynbye.com/catalog/i60.html (this is a total kit, calipers come with it)
LT1 rear disc brakes http://flynbye.com/catalog/i30.html (just part)
Reply 0
Jan 4, 2010 | 11:45 PM
I would look here, they have everything !!!!!!
http://www.ssbrakes.com/
Reply 0
Jan 5, 2010 | 10:48 AM
hmm I must be missing the camaro drum to disc kit cause the only ones I see are for stangs.
Reply 0
Jan 5, 2010 | 12:18 PM
Quote: hmm I must be missing the camaro drum to disc kit cause the only ones I see are for stangs.
Its in there somewhere,,i have seen it.
Or just google break conversion camaro !!!!!!
maybe this helps ?
http://www.ssbrakes.com/content/imag...logs/GM001.pdf
Reply 0
Subscribe
