lt1 style brakes
Old Jan 7, 2010 | 08:27 PM
wht96's Avatar
lt1 style brakes
I was wondering what exactly is the difference between the drum brake rears and the disc brake ones. Awhile ago i purchased a lt1 brake setup backing plates to rotor and thought i would be able to do the swap, by trimming the axle flange and using the lt1 style backing plate. I read some where that this isn't possible because of an axle difference? can someone please give a little insight on this.
Thanx alot
Old Jan 8, 2010 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: lt1 style brakes
With the newer style rotors, you shouldn't have an issue. Check the following thread, post #13:
https://www.thirdgen.org/forums/brak...drum-rear.html
Rather than trimming the axle flange, you might consider Ed Miller's kit (the above link details the install):
http://www.flynbye.com/catalog/i30.html
JamesC
Old Jan 8, 2010 | 10:41 AM
wht96's Avatar
Ok, so the axles are different so if i trim the flange bolt on the Lt1 style backing plate, Of course with the two extra bolt holes, and use the lt1 style rotors then then this will work? I understand the the kit being sold is an easy option but if this will work and i already have it it makes more sense to use my existing peices. esp since i dont plan on ever returning to drum brakes.
Old Jan 8, 2010 | 12:46 PM
JamesC's Avatar
Have you seen the following (note the cutting of the axle flange):
https://www.thirdgen.org/ls1reardisc
JamesC
Old Jan 8, 2010 | 12:59 PM
wht96's Avatar
Yes i have seen this, That was kinda what i was basing my swap off of but i wasn't sure of any differences with the lt1 to ls1 style. I just didn't want to miss anything, or rip my car apart only to find out that it wont work and end up needing ed's kit. thanks for the help.
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Aug 28, 2015 05:57 AM
zayne0
Aug 24, 2015 07:22 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
