Line Lock/Roll Control?
Old Jan 29, 2010 | 11:59 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I picked up a line lock unit and all the parts for $30 but the guy lost the diagram. Anybody have pictures or a diagram of how they are supposed to be plumbed?
Old Jan 29, 2010 | 12:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Line Lock/Roll Control?
You just hook it up inline to the front brakes. Right between the master cylinder and the distribution block for the front left/front right. (unless it's a 4 connection line lock, then you can hook it up after).
Then just wire it up to power, and a switch that you put where you want in the car.
Old Jan 29, 2010 | 12:31 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
It's a 4 connection, I can't figure it out haha.
Old Jan 29, 2010 | 12:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Ok, just tie in to your front brake lines after the splitter (whatever it's actually called) and you're good to go.
Old Jan 29, 2010 | 12:43 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
2 of 4
Attached Thumbnails Line Lock/Roll Control?-100_0802.jpg   Line Lock/Roll Control?-100_0803.jpg
Old Jan 29, 2010 | 12:45 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
4 of 4
Attached Thumbnails Line Lock/Roll Control?-100_0804.jpg   Line Lock/Roll Control?-100_0805.jpg
Old Jan 29, 2010 | 11:10 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Thanks, thats a bit of a help.
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
