how do i install my adjustable prop valve?
Old Feb 1, 2010 | 04:44 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i just bought this proportioning valve to go with my rear disc conversion. http://www.summitracing.com/parts/SUM-G3905/ . whats the best way to install it? can i eliminate my stock prop valve?
Old Feb 1, 2010 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how do i install my adjustable prop valve?
you can eliminate the stock pro valve, just tye the front 3 lines together, your going to have to re-flare the lines and find the proper "t" fitting. What i did was take the propvalve, cut the front section off, weld up the holes and use the remaining piece for the junction for the front brake lines. No modification of the lines required!
for the adjustable valve, plumb it inline with the rear brakes right off the master. Again, you will have to do some flaring and such to get it installed. I installed on recently, and i didnt want to deal wit reflaring the hardlines, since they are stainless, so i dug around and found the proper sized bubble flare union for the rear hardline, made a little adapter and a short bent piece off the master. Pretty straight forward, but finding the right parts took forever.
Old Feb 1, 2010 | 09:24 PM
thanks for that info. one more question. i have 1/4" line to the rear and my prop valve is made for 3/16". should i run new 3/16 line to the rear or just find some fittings to adapt it? thanks again
Old Feb 1, 2010 | 09:41 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Think I'd go with the new 3/16" line. I don't like any more adapters and fittings on brake lines then I absolutely have to use!!!
Old Feb 1, 2010 | 10:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
my valve came with the proper 1/4" inverted flare x 1/8 npt adapter, local auto parts store, napa, ect should have it. No point replacing the entire rear hard line, unless its rotted, maybe a good time to check.
Old Feb 1, 2010 | 11:25 PM
thanks for all the help. here is what i came up with in the pic. I'll fab a bracket soon. tomorrow i'll take her for a test spin to get the adjustment right.
Attached Thumbnails how do i install my adjustable prop valve?-prop-valve1.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
dcbsracing007
Aug 18, 2015 07:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
