front brake upgrade...need help
Old Feb 2, 2010 | 10:42 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i'm trying to find a good front brake upgrade to match my ls1 rear brakes. i cant seem to find the info i need. maybe some of you senior members have seen the thread i need. but anyway my question is what is a good caliper i can use? i'd like to use the ls1 front calipers but i know the rotors are bigger and has a completly different setup. thanks
Old Feb 2, 2010 | 11:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: front brake upgrade...need help
Aside from stock or stock replacement, there are no big brake upgrades (rotors/calipers), as far as I know, that don't require spindle modification. Check the LS1 from Ed Miller:
http://www.flynbye.com/catalog/i47.html
And, of course, the whole package (one of several):
http://www.flynbye.com/catalog/i7.html
JamesC
Old Feb 2, 2010 | 11:05 AM
that just looks like a trailer hub. i wonder if a trailer hub will work. i think $475 i pricey.
Old Feb 2, 2010 | 11:12 AM
JamesC's Avatar
You could always modify the spindles yourself and piece together the parts. Whether you'd come out ahead in the long run or not, I'm unsure.
JamesC
Old Feb 2, 2010 | 06:31 PM
anthony714's Avatar
the only real upgrade factory wise wold be a 1le but thats not practical given the availabilty and the mods are the same as any newer ls1/c5 mod
do what i did,scratch and claw for ls1 parts. theyre dirt cheap on flea bay or craigslist. get calipers,abuttment brackets(usually together) and rotors and pads. all can be bought new at autozone of you need also. then get a set of brackets from eb ,tak eout a saw sall and a tap swet and you have brakes ..12+ inchers. i lucked out and got ls1 calipers and found c5 abuttments so i bought 13" c5 rotors instead of ls1 and have 13" front but theres no difference of you just did 12" ls1. if you scratch and claw and dont mind older stuff like rotrs you can do for less than 300
Old Feb 2, 2010 | 07:12 PM
so how did you install the rotors? did you cut the original rotor off of the hub? do you have any pics of yours? what if i used the stock rotors would the calipers work if i fab a bracket?
Old Feb 2, 2010 | 07:41 PM
anthony714's Avatar
no,the stock rotors and calipers ownt work with anything else. you can use your stock rotors and cut the rotor of and use it as a hub then the new ls1 rotor just slide ove rit. i didnt cut my off. i had the luxury of being able to buy the parts from eb. only thing is the the ls1 set up kicks front wheels outward about 3/10" each side. probably wont matter on most set ups. even i you could use the stock calipers for something they wouldnt work except with a smaller rotor since theyre "radiused" for alack of a better term and only really work on a 10" rotor.
i dont know your deal butt if its amoney issue and you really want better brakes youre better off ls1 only becauase theyre more plentiful and cheaper. you can buy new rotors pads and calipers for your stock swet up but when you price all those parts togwether its costly and youll still have 10" brakes
Old Feb 2, 2010 | 08:41 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I bought the rotors, calipers, brackets, and a set of stainless hoses for ~$200 shipped. I made the adaptor bracket at work. I'm paying a machine shop about $80 to turn a pair of stock rotors down to fit my drilled and slotted rotors. New bearings about $60. I'm at about $340 on mine and I still have to cut up my spindles and tap the holes out and bolts are prob about $10 bucks in the end.. Oh and the wheel studs will be about $20-25 bucks. So just under $400 bucks in the end. I didn't add my drilled and slotted rotors to price since I got a set of freshly turned rotors with my calipers...
Old Feb 2, 2010 | 09:41 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I just finished my fronts today, I did c5 setup. You can get most of the stuff from ebay and craigslist like the man said. You can make your own bracket from a templet on line, or by one from ed miller. I drilled and taped my spindles on the car and cut the extra metal off the spindles with a sawsall. I did my hubs myself
Old Feb 2, 2010 | 11:58 PM
that looks nice. so you cut the disk off of the stock rotor? i shouldn't have any problems making the brackets myself.
Old Feb 3, 2010 | 12:31 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I used a cutoff wheel to cut the disk off the rotor. The only pain was the first 1/8 inch on the outside front edge on hub needed to be cut to 5.89 inches so my rotors fit over it. I used my table saw with a large cutoff wheel to do this.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
